This is a report from Oil Analyzers Inc. for my 2004 Kubota
D902-E 3 cyl. diesel engine. It's installed in a Grasshopper
lawn mower (722D).
Lube= Amsoil ACD 10w30/SAE30
Sump Capacity= Approx. 6 Quarts
Filtration= Amsoil full-flow EaO-15 and Amsoil Bypass EaBP-90
Also installed= Amsoiler pre-luber
Unit Time= 1500 hours
lube time= 250 hours/5 months
filter time (both filters)= 500 hours/8 months (bypass still gets hot to the touch)
makeup oil= negligible amount
lube change= no
filter change= no
IRON__9
CHROMIUM__1
ALUMINUM__1
SILICON__4
SODIUM__3
POTASSIUM__1
BORON__2
MAGNESIUM__10
CALCIUM__3738
PHOSPHORUS__1227
ZINC__1364
FUEL GC__0.7%
SOOT VOL.__
WATER INFRARED__
VIS 100C CS__11.2
TBN__11.60
I-R OXIDA__31
I-R NITRA__13
Any questions/comments are welcome.
Also, if anyone has any suggestions as to when I should sample next, and how long is the maximum time I should run the filters for, i.e. is it o.k. to run the bypass filter until it doesn't heat up anymore?
Thanks,
Bob
lawn mower (722D).
lube change= no
filter change= no
IRON__9
CHROMIUM__1
ALUMINUM__1
SILICON__4
SODIUM__3
POTASSIUM__1
BORON__2
MAGNESIUM__10
CALCIUM__3738
PHOSPHORUS__1227
ZINC__1364
FUEL GC__0.7%
SOOT VOL.__
WATER INFRARED__
VIS 100C CS__11.2
TBN__11.60
I-R OXIDA__31
I-R NITRA__13
Thanks,
Bob
