History:
I purchased my 2007 Civic LX new on 5/3/2007. This car is my daily driver and is used almost exclusively for short trip driving to/from work, which works out to about 80 miles per week. For those who are curious, the odometer is at ~8,300 now.
I drained the factory fill at 1,500 miles and have used Amsoil 0W-20 ever since. I currently use a 6-8 month OCI, but am working towards a 1 year OCI. The automatic transmission has been converted to Amsoil ATF via the drain/fill method.
Fuel & Fuel System Cleaners:
I used Shell V-Power 93 for the first 18 months, and treated each tank with 5.25 ounces of Lucas UCL. I would treat the tank burned prior to each oil change with a 15 ounce bottle of Red Line's SI-1.
While the engine seemed to run well, I noticed that engine performance seemed to suffer when using the last 40% of each tank of fuel. I then took a friend's advice and used Shell 87 octane instead of V-Power 93. The engine seemed to run smoother when using Shell 87, so I have been using it ever since. I also stopped using Lucas UCL because there was no perceptible difference between in engine operation or fuel efficiency.
I recently purchased a quart of FP+ from LCD and added 2 ounces to my Civic's 13.2 gallon tank while filling up with Shell 87. The engine seems to start easier, runs smoother and there is no perceptible change in performance as the tank falls below the 40% mark. The engine is now on its second tank of Shell 87 treated with FP+ (using recommended treat rate) and my results have not changed. I did not experience a significant change in fuel efficiency, but was not expecting to see one due to the engine's use of synthetic lubricants, exclusive use of Top Tier fuel and low mileage. I am very pleased with FP+ and will update this post if anything changes.
