Originally Posted By: Papa Bear
Valve float from over-reving ??
Not likely with an auto trans.
I bet if you put it in L and held it to the floor you would redline it....
You could drive it all day like that and not bend a valve. The revlimiter will keep it from overreving and the auto trans won't let you downshift into the wrong gear.
I second valve to piston contact. When I was 18 I built an engine for my GN, had a hangover the day I put the cam in. Timed it wrong, and bent all the intake valves. After removing the heads, the pistons looked untouched but it was obvioius what happened.
It's not a timing issue with the OP since all valves weren't bent. Was the spring pressure checked on the offending valve? I've seen springs lose half their tension before.
