Jigen,
Your silicon is barely high enough to indicate any concern, I thinkt he focus on it is overblown. If you are concerned, seal it up better.
Your results are fine IMHO. Seafoam absorbed through a vaccum hose goes where? All over the engine, that's where. You can't interpret a UOA where seafoam was used.
Do a couple of cycles of THE SAME OIL...i.e. the same synthetic. And then do a UOA following proper sampling techniques (drive 20-25 minutes beforehand, don't idle, take sample from middle of drain while still hot).
Your results will be fine.
You've got a rock solid engine on your hands. Also, Dyson is worth the money....if you need him. You don't.
Joe
P.s. Don't use any more additives. Seafoam wasn't a bad idea, but you've done it now and you don't need anything else than good filtration and a quality synthetic.
