Mobil V Twin 20W-50 Fully Synthetic Experiences
I used it in a Commercial Briggs 16 HP VanGuard V-Twin and sent in a couple samples to Blackstone.
The engine is 20 years old and I used to use Mobil-1 15W-50 RedCap as is was a 1400 ppm ZDDP product vs GoldCap and SilverCap which are now 1200 ppm ZDDP products.
I like V-Twin with it's 1600 ppm ZDDP levels.
Long story short.... the M-1 V-Twin samples all came back with zero for copper/iron/lead etc...wear metals. Amazing! About 100 hour changes.
I also like Motul 300V 15W-50 or 5W-50 with high ZDDP and Moly along with the fact the 300V is a double synthetic GRP V....though priced at $15.00/qt.
Anways...the M-1 10w40 mx4t is a good choice as well with 1600 ppm ZDDP.
Amsoil's ASE with 1150 PPM ZDDp SAE 30 is another great choice.
BUT......nothing beats M-1 V-Twin.....I mean 1600 ppm ZDDP and a very beefy synthetic base,,,,
Outstanding choices!
When I was at the mower shop last the serviceman was replacing a Kohler short block.
He said the owner while not using it much decided on using a conventional 10W-30 oil.
The bearings mostly were shot with some cylinder scoring.
His lube of choice for any V-Twin is M-1 15W-50 or M-1 V-Twin.
Commercial engines can run a couple thousand hours he claims...with a high ZDDP synthetic oil.
Especially for very hot running engines...M-1 20W-50 is the 2, 000 pound gorilla of synthtic oils.
A lot of the OffShore Boat (Cigarette style) have made the switch in ther 700-1500 HP engines. Teardowns are amazing I have heard!
I don't understand how a conventional 10-30, regardless of the usage factor, would cause ruined bearings/scored cylinders. Something else must have been involved. A Kohler should last forever with any 10-30 out there, I'd think....
Newer non hdeo oils have low zddp levels. I spoke to a Kohler rep who said you need 1200 ppm ZDDP min for any v-twin to last.
