I can't say either way but considering the amount of air present pre & post filter after an oil change (w/ filter), I question the benefits of a few ounces of oil added to a horizontally mounted oil filter on startup.
Myself, I worry more about reducing the time from sump to pump on dry startup. As a result, I install the oil filter last after the oil sump has been filled (pull drain plug, remove oil filter, replace drain plug, add oil, install oil filter) thereby, in theory, allowing oil to displace air that may have been trapped in the oil pickup tube/strainer assembly by a restrictive oil filled filter.
Also if possible, I spin the engine with a non-chipped ignition key prior to the initial startup.
