According to an article I have read, diesel fuel is fairly unstable. And the drop-out of carbons is starting to plug fuel filters earlier than OEM filter change intervals. Bio-diesel fuels are even more prone to this. With the high pressure, heating, and then return to the fuel system mixing with cooler fuel...carbons are dropping out. It seems that moisture and water are a factor and microbes are growing in the fuel also plugging fuel filters prematurely. The most highly refined diesel fuel is not escaping from this carbon drop-out. At this point, the only effective way to fight this is to change out the filters earlier than OEM intervals.
