Originally Posted By: tjbeggs
Alright then. I will let you guys know how it all works out. I hope good! And I hope its not money wasted over the standard 1734.
tj, you got buried in the bypass valve slugfest
I don't know anything about it. It's got a great rating over the regular 51734. Impressive flow potential Same multipass spec's at a higher efficiency. (betax=75 instead of 20)
Part Number: 51734XE
UPC Number: 765809527348
Principal Application: Synthetic Media Version Of 51734
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Glass
Height: 8.122
Outer Diameter Top: 4.266
Outer Diameter Bottom: Closed
Thread Size: 1 1/2-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 4/75=10/30
Burst Pressure-PSI: 200
Max Flow Rate: 28-30 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.967 3.587 0.340
Part Number: 51734
UPC Number: 765809517349
Principal Application: Ford/IHC Trucks w/7.3L Turbo Diesel (94-03)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 8.093
Outer Diameter Top: 4.282
Beta Ratio: 2/20=10/30
Burst Pressure-PSI: 385
Nominal Micron Rating: 19
Gasket Diameters
