06 Dodge/5.9l Cummins/JD Plus 50 0w-40
London,KY
Here is a sample of JD Plus 50 0w-40. Sample performed by Fluid Analysis (oilscan.com through JD). Miles on oil 10671/263hrs. Total miles on unit 96834. Quad Green air intake, Quad race box, straight piped, and a Fleetguard LF 16035 filter used. No make up oil. Oil was not changed. I will resample at roughly 400 hrs.
IRON 36
CHROMIUM 2
LEAD 3
COPPER 3
TIN 0
ALUMINUM 5
SILVER 1
SILICON 10
BORON 100
SODIUM 3
MAG. 120
CALCIUM 2976
PHOSPHORUS 1224
ZINC 1465
MOLY 79
FUEL UNDER 1%
VIS. 14.98
WATER LESS THAN .05%
TBN 8.84
OXID 10
NITR 11.0
F-SOOT 1.62
ANYTHING NOT LISTED WAS AT 0
OIL WAS INSTALLED 12-4-08. THIS TRUCK WAS STARTED ALL WINTER WITHOUT ANY USE OF COOLANT HEATER EVEN DOWN TO -2*F. IT HAS HAD ROUGHLY 25% HARD TOWING ON THIS RUN ALONG WITH EXTENDED IDLE TIME.
Looks very good to me considering the miles on this oil sample. Still seems like a lot of additive left even after 10,000+ miles.
tuner or chip? stock hp and torque?
great base stock oil. wish it were avail in this area. all the great adds. boron, moly, mag.
the base stock quality helps with long turbo life
will Dodge/Cummins cover their engine under warranty with a CH rated oil?
2 dealers here told me no way.
Deere will probably keep it a CH rated unless the EPA forces them to CJ
300 hp tractors with CAT converters and DPFs, what is the world coming to.
http://www.deere.com/en_US/parts/partsinfo/oils_and_lubricants/oil_0w40.html
IRON 206
CHROMIUM 4
LEAD 2
COPPER 7
TIN 3
ALUMINUM 15
SILVER 0
SILICON 8
BORON 40
SODIUM 5
MAG. 3
CALCIUM 1511
PHOSPHORUS 764
ZINC 890
MOLY 1
Barium 0
FUEL antifreeze 0.0
flash point in F 420
Insoluables % 0.3
SUS VIS. @210F 64.9
cST Vis. @100C 11.59
WATER 0.0
TBN 5.4
2005.5 A5 Diesel Jetta BRM engine...107,364 miles total 5,978 miles on sample...no additional oil added...no additional additives added. PULLED VC OFF TO INSPECT CAM WEAR PRIOR TO SAMPLE!!!Cam lobes showed moderate wear (edges very sharp) no visible damage to followers or rollers with #3 exhaust showing most wear...Added Bypass oil filter and magnetic drain plug at this oil change along with full bottle of ZDDPlus and will drain again and sample at 5K.....Thoughts anyone?
1quartlow,
You should start a new thread for this, that way more people will notice it and it won't interrupt this thread.
It would be interesting to hear others thoughts on this, but I would suspect a metallurgy problem is at hand here...
Originally Posted By: REDDOG
1quartlow,
Sorry...I thought that I had started a new thread (I copied someone else's UOA and pasted my results to make it easy and I posted by mistake)
Thanks
