Partly for the sake of simplicity since I like to run the same oil all the cars, partly because I'm convinced it's an excellent oil, I'd like to run Castrol Syntec 0w30 "GC" in an 06 Cadillac SRX with the 4.6L Northstar. This is the LH2 rear wheel drive / all wheel drive Northstar variant, used in our SRX as well as the STS and XLR, with variable valve timing on both intake and exhaust cams as well as some other changes from the tranverse mounted FWD Northstars.
GM factory fill is Mobil 1 5w30. A few other oils are listed to meet the GM spec for this engine as well, but GC is not among them. Working on the theory that GC will nearly always be able to sub in for Mobil 1 5w30 with no ill effects, I'm guessing it will be no problem to use GC in this application. I like the 0w30 weight of GC because I think it flows quicker at colder temps, and I like that GC is actually a thicker oil than M1 5w30 and thus should provide more than adequate hot weather protection as well.
If anyone else has thoughts I'd be happy to hear them. Thanks.
