I was just wondering .... I have a 1.8T 05 GLI and drive about 30 miles to worl one way and it is mostly highway miles. Is highway driving easier on an engine and oil than city driving?
I've heard something about a system (BMW?) that periodically applies pressure to the brakes for a split second to heat them up. Something about helping to evaporate moisture if it rains and/or keeping the rotors warmer for better braking efficiency.quote:
Originally posted by jaj:
Right - highway miles are easy on your engine and drivetrain, but I've had two cars with serious disk brake problems because of it! One VW diesel and one Mercedes diesel - both did about 2500 highway miles a month for several years, and both had the same problem. One was mine (the VW) and one was my wife's (guess which one!).
The brakes get cold and wet and stay that way, and after a year or two the rotors corrode badly and the calipers get seized up with salt and corrosion. Everything in your car works better when it's kept warm!
Cheers
JJ
Ditto to everything Patman said. I'll take a car with 200,000 highway miles vs one with 50,000 city miles.quote:
Originally posted by Patman:
Highway driving where you're at the same steady speed for a while is definitely the best condition for an engine and for the oil. With the engine at a steady speed and under low load (on flat roads that is) and the oil up to full temperature, you have virtually no engine wear at all.
Some of the new Audi's include that feature as well...I believe I read that in an article on the new Audi RS4.quote:
Originally posted by lucaq:
I have heard of that system also... my friend who just finished his ASE was telling me about it... he said it was MB also
I've been behind drivers that do that themselves every few seconds for miles on end..quote:
As said before, the age of the car for starters, Second look at the brake and clutch pedals. If they are well worn, they are from lots of use and lots of city driving.quote:
Originally posted by 00Max00:
The problem is how do you know those are highway miles?
