Don't feel bad : I ran Amsoil TSO 0W30 in my Chrysler 2.7 for 7600 miles and it was shot. Plenty of TBN left and the wear numbers weren't all that bad, but the oxidation and nitration were past the point of the oil needing a change.
TBN is not the only or best indicator of oil life. There are other things.
As far as Blackstone's recommendations, I have very little faith in them based reviewing the many reports that have been posted here. I see very little depth or expertise in them; the same phrases being parroted over and over again. And here we have an oil whose TBN is approaching the lower limit, and Blackstone recommends running it 50% longer !(?)
I'd be very surprised if the TBN of virgin ST is in the 10.5 - 12 range. 7 or 8 would be typical, as it is with most consumer grade conventional oils. Amsoil or Mobil 1 HM 10W30 - yes, they're certainly in the 10 - 12 range.
