I have a turbo miata street/track toy.
I'm running it at 11.5:1 in boost, with about2000 miles on the motor now. I changed the oil for the second time (after 500-mile break-in) and noticed that the Rotella 5w40 dino was very dark...well, as black as black can be. Oil temps never went above 230*F so I've ruled out excessive temps.
A friend who builds force inducted track cars claims that fuel contamination will be an issue, and I should expect to change the oil after every track day because of the rich mixtures.
I switched to Rotella 5w40 synth yesterday. Do I need to worry about color? Could the blackness result from assembly lube still in the motor? What indicates fuel contamination?
