I just didh a drain and drop my a recentley purchased used '03' Honda Odyssey Ex with 3.5L & 5 Speed transmission with 70k Honda Certified used miles. The manual says to do a drain and fill 3 times. Approx 3 quarts comes out each time. I could not find the fill plug so I used the painstaking diptube I only had time to do it once but I definitely need to do it the other 2 times as the fluid was last changed 40k miles ago and these transmissions are known to be problemattic. Does anyone know where the fill bolt is?
thanks
thanks
