Originally Posted By: Rolf
Originally Posted By: mareakin
Started the 2007 Corolla in very cold weather today, around 15 degrees, and it knocked intermittently for a lil before being normal. Is that typical?
Engines with hydraulic lifters can make a "knocking" sound in cold weather until the lifters "pump up".
It's not really a problem.
If it bothers you, move to a lower viscosity motor oil, preferably one which begins with "0W...".
You'll get oil to the lifters faster and eliminate the problem.
That's all fine and dandy, but Toyotas now use solid lifters in between the cam and valve.
I'm guessing it was the timing chain - known to be a bit noisy on these engines
