Originally Posted By: Bobert
Originally Posted By: tig1
Weaker? Are is it just different? You would have to be a lubrication engineer to determine that.
If you wanted to use that argument with every thread on this board, you would have to basically eliminate 99.9 % of the board members and be left with basically a handful of people. It would be a fairly boring place.
Yes, fiction is often more interesting than facts.
However, an elemental analysis by itself cannot rank motor oils since it does not measure base stocks or non-elemental blend stocks and additives.
