http://www.strasseschweiz.ch/dcs/users/2/Buetehorn.pdf
This is a cool and recent presentation, IMO.
I note that API SM and ILAC GF-4 get pooh'd on when it is stated that recommended OCIs in export countries with high sulfur fuel are:
15.000 km / 1 yr with ACEA A3/B3-07 oils and 7.500 km / 1 yr with API SM / ILSAC GF-4 oils.
In Europe where the gasoline is "better" (less sulfur) and an oil meeting GM-LL-A-025 is used (Mobil 1 0W-40 meets this, BTW), recommended OCIs are 30.000 km / 1 yr.
This is the only document I've ever seen that describes the requirements of GM-LL-A-025 and GM-LL-B-025.
The GM Global Engine Oil Specifications, GEOSA and GEOSB, are interesting since GEOSB exceeds ACEA C3-07 in most measures according to Slide 16.
