The viscosity blending calculator is meant for use with base oils, not fully formulated oils that have VIIs added. However, I think it should work well enough. What happens is the base oils mix together to form a new base oil viscosity and then the VIIs from each oil mix together and work off the new base oil viscosity. A 10w30 mixed with a 10w40 is going to end up either a thick 10w30 or a thin 10w40.
If you mix a straight weight with a multigrade you will spread the VIIs from the straight weight over the whole thing. [Edit: Oops, I meant to say the VIIs from the multigrade would mix over the whole thing.] For example, you could mix straight 30 with 10w30 and end up with something like a 15w30 or 20w30. Or you could mix some 10w with some 10w30 and get maybe a 10w20.
I do think it is better to mix closer grades like 10w30 with 10w40 rather than wide apart grades like 5w20 with 20w50
--that just seems to be asking for trouble. Sure would not use it in the winter, but the 10w30 / 10w40 mix is fine for winter if you normally can use a 10wXX in winter.
[ May 12, 2005, 12:58 AM: Message edited by: TallPaul ]
