I believe some of the independent blenders are still actively pushing GF-3 out the door, too*, so don't assume anything in the case of some store-brand oils. (That said, I finally found SuperTech conventional and synthetic in GF-4 out here on the west coast - their 10W-30 synthetic looks real interesting at $12.04 in the 5-quart jugs!) For those who want a deal on a name brand GF-4, check out Dollar Tree Stores: Phillips 66 TropArtic Synthetic Blend GF-4 5W-20, 5W-30, and 10W-30 for a buck-a-quart. (I personally relieved the Rancho Cucamonga store of three cases of the 10W-30 synthetic-blend yesterday. The manager thought I was crazy - yeah, like a freakin' fox. Thank goodness for store managers who're clueless about the latest motor oil developments.
*API retracted earlier efforts to crack down on continued GF-3 production according to
Lube Report last week - this latest "march forward" in oil specs is turning into a semi-fiasco even though the spec, itself, really is a worthwhile improvement. The problem for the independents is that Group II+ and Group III base stocks are in very high demand for the 5W-20 and 5W-30 viscosities. On the other hand, ALL of ConicoPhillips multi-weights through 10W-30 are now blended using Group III and Group II exclusively ("when ya' got the pump, ya' get the jump") which qualifies them as syn-blends. Blending in Group III base stocks for these GF-4 multiweights is great for consumers but not completely necessary - Group II will do with a reasonably solid additive package. I'm just wondering whether ConocoPhillips' strategy is to further tighten the market on available Group III and Group II+ supplies in order to squeeze the independents out once and for all. Remember when it was posted six months ago or so on BITOG that ALL of the upcoming conventional Mobil GF-4 oils would be blended with
only Group III base stocks? While I was vocal to the point of outright skepticism at the time, now I'm not so sure. Might ExxonMobil have also had a similar strategy in mind to what I'm suspecting of ConocoPhillips? If so (and that's by NO means a given), ExxonMibil's lawyers might've suggested best not to make a public announcement in print to avoid an antitrust investigation. (ConocoPhillips might've left themselves open to just such a scenario by publically announcing that their entry-level GF-4 oils would henceforth be synthetic blends. Dunno - just a wicked thought. Y'all just take it as you will . . .)
