Originally Posted By: momomeister
Originally Posted By: emaax
btw... API SM M1 0W40 has a good point... it keeps the engine very clean even if it is a high milleage one
the deposits simply float dissolved equaly in the oil...which is amazing they dont down fall down to the oil pan and acumulate in layers so easy...
so looks a good break-in oil - i would dare say - its a thin weak oil that does a good job at cleaning the engine
back to api SJ SM
SJ is better than SM
Same goes with SL versus SM?
yy ... and I found the good SL syntethics, still being more expensive than the SM's.
question pops up... why companys would do that..? isnt normaly, "what is more modern late generation", more expensive?
which is not the case of lots of SM's, they are a bit cheaper
