i have API SM Mobil 1 0W40 at the moment...
and i can ashure you that SM is the biggest [censored] ever allowed.
one can easyly see the consequences:
for engine-wear sake API SM must be desregarded... it is the codex alumentarius of the engine health.. it follows the directive principle: "to prohibit access to all the good nutrients that really feed and suport your body"
you see all modern engines here in europe... just listen
they sheer
they clunck
they knock
the OCI recomendations also to blame in that...
you see in UOA almost no oil does 15K km and "the market" is recomending 20k 30k 50k ... nonsense
every earable problem simptom, related to engine lube that you can possible imagine... it happens in modern engines around here.
"they" say the engines are made to take the damage... high temp combustion chambers, lean AF ratios, etc...
other point being defended with SM is ...
... contamination of catalitic converters by the antiwear additives... omg... so stupid!!!! if the engine is well lubricated... there are no oil leaks to the combustion chamber nor any volatility that migh go out the exaust system...
not even if the engine has exaust gases recirculation
so you test it,,, and see the damage... M1 0W40 "Protection Formula" is the most clear example... yes ... you can yes see a increase in performance if you come from so called pure semi-syntetic or mineral oils ...
the viscosity grades also break down... so that means that the oil is not stable... so ... it is volatile and will be "noticed" at exaust gases ... so.. no wonder if is SM compliant because it wears the engine but... "its ok" it can go to exaust gases... "emission sake", because the antiwear aditives are not present... and do not harm the catalitic converter.
well.. the ZZDP package seens to be presente... 0,1 phosfor
but it also has a 10 TBN and high sulfated ash... problem too much aditives that do not hold toguether so well...
its a cool oil for total conservative driving... no-city, and mainly straignt read driving
emission standards is such a [censored]... if you live in a crouded town... you will see that is useless to have the cars tuned at idle if the pollution is all made in aceleration.. wich is not tested not controlled or even regarded...
such a [censored] the low emission standards and API SM oils
... thus...
maybe there are oils with full SM complience but we dont even hear about them... cepsa perhaps... where the aditives "hold" toguether
also .. the workshop oils are diferent from "open market" to the public consumer oils
they have wear protection ... and they are all legacy specifications..
if the workshop owners are really willing to steal the car owners billing for oils that .. look modern... but fill the engines with the cheapest they can find... this also happens here...
but regardless the factory recomendations... as what is told to the clientes... all the models wither new or old are filled with the same oil that cames from the 208 litle containers and mainly 10w40 here for south europe
well... this is what i see here in europe after some month "looking" at, what the oils world is about... and seeking the best for my undersquare a 1.6 cc engine
"my 2 cents"
conclusion:
SM protects "economical and political interests"
NOT engine wear.
Cheers... (not "shears"... please
