Originally Posted By: rumple
Drain and refill. The capacity of the transaxle is 4 quarts and it has a magnetic drain plug. There was a fair amount of fine schmutz on the magnet which I of course wiped away.
As I said Toyota has this fluid going out to 100,000 miles, but based on many analysis's over on the Priuschat site, it would appear that at least an early change is a good idea and perhaps then every 30,000 - 60,000 depending on driving conditions, with higher speed highway drinving correlating wearing out the fluid faster.
Toyota WS is cheap (I paid $7.80/Q) and the job easy with a fill and drain plug - why not change it at least once?
Color - Red, looked pretty good
Transparency - Not as transparent as virgin, but not too bad
Smell - No burnt or otherwise nasty smells - close to virgin Toyota WS.
I live in NJ (NYC metro region)
Highway speeds are generally 65MPH and lower. When I drive I set the cruise control for ~58MPH (60MPG at that speed).
The car is a suburban "mommy" car with mostly very short trips (3 yellow bars or less). We owned the car since new, March 2007.
Rumple
The Toyota drain and fill typically leaves behind insoluable junk on the AT pan. That in mind, maybe Toyota WS doesn't leave behind as much as Dexron III or Toyota T-IV.
