Pressurizing a 2-2.5 liter 4 cyl. with 15psi of boost would act like a 4-5 liter v-8, buts that's a lot of boost for mass produced engine. More reasonable 5-7 psi boost now the 4 cyl. acts like a 6 cyl. With all the plumbing, intercooler, etc how much weight/space are you really saving?, not just going ahead and put in a v-6. The v-6 will get better low-mid range torque, be easier on oil, and get similar mpgs.Porsche? had 4 cyls up to 3 liters but need hp robbing balance shafts to keep it accectable to potential buyers. Practical common limit 2.5 liters. This should get you 185-200 hp NA. In a small light fwd car with torque steer limits do you really need more? I see little need usually for pressurizing gas engines anyway, diesels whole other thing (much better suited) .Actual displacement instead easier to get, more fun, more reliable than simulated cubic inches.Rather a moot question anyways, so here we are "mooting" it.
