Quote:
Sorry, I forgot to answer this question. No, there had not been a sudden loss in performance or fuel economy prior to the treatment. I added the Redline SI-1 only for preventive maintenance purposes. The only thing that affected fuel economy is that ever since I replaced the upstream Oxygen Sensor with a Bosch OE style unit 6,000 miles ago, the fuel economy seems to be a bit better (and more consistent).
It's criticize The Critic month.
Normally, if you don't have problem, pouring a miracle elixir in your gas tank won't fix it.
You mispilled year in your signature
