i am with doug on this one. "meets or exceeds" in marketspeak means "fooled you again". the prime example of this is GM4718M, which isn't a euro spec, but an american one. there are exactly 9 oils (14 vis) that meet this spec, but nearly every oil out there will strike up with "meets or exceeds". this is one of the ones that really toasts me, because part of the spec is that you have to RETEST if you change your formulation, which some of the boutique oils do with nearly every batch.
this goes along with the "it's too expensive to certify" routine. however, if Northland and CITGO can afford to certify, and live inside the specs, the other folks don't have much of a leg to stand on...
