Originally Posted By: Whimsey
Originally Posted By: brianl703
Ford issued a TSB recommending the use of Mercon V for all power steering systems that called for Mercon.
They did not extend this to power steering systems that call for Type F, but I've used Mercon and Mercon V in those with no problem at all.
In my 1996 Contour I continue to use Type F. I left the factory fill in for 9 years, "my bad
" . It wasn't black but a darker red after all that time, good shape for 9 years though. I've replaced several quarts with Valvoline and WalMart's Type F via the turkey baster method. So far after 13 years come this December it steers great and doesn't leak. I don't want to "tamper" with success
My 2002 F-150 came with Mercon in the PS. Turned black after 3 years. I turkey based it with several quarts of WalMart Mercon and now ran 2 quarts of Mobil 1 ATF, Mercon grade. We'll see if my winter PS "whining" is better.
I've also added some LC20 to both PS units as per directions.
Whimsey
That's funny, before I upgraded to the Jag I drove a 96 Contour "4 banga and a 5 speed" for 10 years, I never once replaced or thought about the PS fluid, even with oversized tires, lowered suspension, and several autocross/track events, there was never a problem with the PS system. These larger heavier cars (luxo boats) I have now seems I have to tend to their needs a bit more often.
OK so Valvoline full syn Mercon V is already in the jags transmission, guess I'll start turkey bastin' the PS system, and I'll just keep with the Valvoline PS fluid for the Caddy.
Thanks everybody.
