http://www.talkleft.com/story/2004/11/28/553/34751
There were about 12 bags of ammonium nitrate that were not put in the barrels. McVeigh stacked them in front of the point of the barrels. McVeigh put a hole in each of the bags and poured some diesel in each of the bags and then rolled them around a bit. The barrels were not mixed or moved. McVeigh put some Tovex in each barrel. I believe that McVeigh also put a major booster charge (Tovex) at the inside point of the V shape of the barrels. I do not know if he put anything with the bags of fertilizer, but it appeared that he was priming everything to make sure it would all go off.
Kinepak was mixed and put in the major booster charge. I believe that Kinepak was also mixed and placed in each of the barrels and, I assume, the bags of fertilizer. The only initiator that I am aware of was the Primadet and at least two regular blasting caps. A Primadet was placed in each barrel on the Kinepak and I believe he placed one in a location in the center of the group of bags of ammonium nitrate. All of the Primadet came to one location. I did not really see how he did each step of the Primadet, but I believe he used two regular blasting caps with green cannon fuse to initiate the Primadet cords.
http://en.wikipedia.org/wiki/Oklahoma_City_bombing
McVeigh rented a storage space, which he used to stockpile seven crates of eighteen-inch-long Tovex sausages, eighty spools of shock tube, and five hundred electric blasting caps they had stolen from a Martin Marietta Aggregates quarry in Marion, Kansas
