My VOLVO S60T5 2001 has 75000m
My transmission was working fine until yesterday morning.
First cold day of the year! When starting the car, I get now a very rough shifting from 2 to 3 !!!!! The balance is ok....no slipping also!
I check the oil level ok .The oil is a bit dirty ( I was thinking to replace it for a while now!!!). But Volvo said lifetime oil !!!!!!!!!!!!!
Replace it only if you have problems!!!!!!!!
Anyway it could not be that causing this problem so suddenly!!!
I disconnected the battery for few hours and reconnect it back... (to try to check if it is not the TCM sofware causing that)...
The 2 to 3 hard shifting still there but it seems to be a little bit softer....
Volvo dealer can only check my transmission software in 2 weeks....
So , I need your expertise!!!!!!!!!!
Thanks in advance
Thanks in advance
