Originally Posted By: gto78
yay and nay, I'll explain. Yay for fit, quality, and extremely high filtering ability. Yay for great clean oil since no dirt gets by. Yay for that awesome ginormous soft rubber seal that makes the filter fit much better than any other filter on the market.
NAY for my major nose dive in gas mileage! All I did was change the filter and BAM, mileage went from bad to worse....as in from 20 to 16. I think its because that filter is more restrictive due to the very small micron allowances.
I changed to an AFE Pro Dry S and my mileage went back up to 20 to 21 range. Keep in mind that I drive and explorer. A small car that doesn't require much power to get itself rolling will not need nearly as much airflow and might not be affected by a close tolerance filter like this one.
Me Too! No lie!
I bought a standard Puorlator Air filter for my 04 Altima 2.5 and the mileage went down. No Lie! I put back the original factory filter on the next tank full of fuel and the mileage went back up. I keep both filters now and play around with them. And No Lie! Every time I put in the Purolator, the mileage goes down. This has been going on for 3 years now. The factory filter is really only a bit dirty and the Puro is clean so I don't get it!
