I'm pretty sure I already know the answer to this question but here goes.....I was greasing the front end on the 93 Aerostar and noticed the right upper ball joint boot is split and oozing grease. The boot still holds grease but is obviously split. The ball joint itself is still good.
Is there anything other than replacing the ball joint, or more frequent greasing that can be done to salvage the boot, and save the ball joint from collecting junk and wearing out? Is there something that can be put around it, without taking it apart to repair the boot?
Thanks
Frank D
Thanks
Frank D
