Originally Posted By: artificialist
Do you have a Chrysler product?
Most Chrysler products have a phenolic piston, which is not as strong as as steel, and tends to enlarge. When that happens, it usually does not retract into the caliper as it should.
There are replacement piston and seal kits.
No, I have a vehicle of German heritage. The Germans like things like special greases.
On my forums there was a gentleman who disassembled and cleaned everything because he's into maximum maintenance. Everything was squeaky clean (you'll see why this is funny later). His calipers started creaking afterwards. When stationary, working the brake pedal caused creaking from the caliper. Many disassemblies, cleanings, and lubricatings later it was still doing it.
He got a pointer to the ATE caliper assembly grease which goes on the piston where it meets the seal. Despite the fact that he tried other silicone-based or whathaveyou greases on assembly, only the proper ATE grease stopped the caliper from creaking. Go figure.
I find it also worth mentioning.... A lot of people phrase responses with comments about the pistons moving in and out, and proper range of motion. There's not a lot of motion involved, at least in a disc brake system. The pads run at zero clearance - they are not withdrawn into the caliper by the braking system they are simply pushed off to zero clearance by the rotation of the disc - nothing more. These are not like bicycle brakes which sit 1/4" off of the rim when not in use. Further, the steel and pad material isn't very compressible, so they still don't move all that much when going to full braking, but there is lots of pressure. This pressure swells anything flexible, and slightly distorts the caliper etc... which is why your brake pedal is moving. On sports cars there's less of this, and the brake pedal is very hard and firm - modulating brake action is then more an act of varying stationary pressure on the pedal instead of the pedal moving up and down.
Anyways....
