Frank,
And most of your examples there are due to people NOT following (like most owners) the recommended OCI. (and there are millions still on the road even with that)
1. Stopped ONLY by Auto-RX? So replacing the rear main seal did not fix it?
I've NEVER had a real oil main leak. The worst I've had is a valve cover leak @ 40k miles. Took the cover off. Spotless. Replaced the gasket.
2. Wonder if the automatic transmission had fluid changes. So the knock stopped and the transmission went on for how many more miles?
3. How many miles on the accord? What was the HISTORY of oil changes. Again, for how long? (This shop owner had the rings "un-stuck" within minutes of applying Auto-RX? Because we all know that the shop is going to take a lot of time to fix problems)
One line comments (testimonials) for me don't cut it.
4. I had (and sold it to a friend who still has it) a 1982 Toyota SR5 pickup with 22r motor. It has REAL close to 300k on it. Runs PERFECT. Gone through 2 carbs but other than the body(mostly the bed) rusted though it is still doing great. Never seen anything but Valvoline conventional every 4k miles. Uses about a 1/2 quart of oil every 4k and is clean under the valve cover.
Maybe that is where you need to direct your product, to shops that don't want to make the $$ fixing a problem but pouring in something that fixes it another way.
Quote:
you just spent your money (when we all had some) heres some reasons why its more important than ever to use Auto-Rx as preventive maintenance
Again, HOW is it saving money spending it for something that I have never NEEDED? (again, I have never had "issues" that Auto-RX would fix...)
Quote:
I asked the same thing(s) and well, I got a tisk tisk from the mods/owner. So watch out here.......
Thanks Dargo for the tip! I'm not worried. I believe and have seen Auto-Rx clean up some stuff. But I am convinced that the stuff it cleaned up was caused by lack of design or more likely LACK of PROPER maintenance.
The stuff works, but I just don't think it is needed every second a engine is run.
But I don't sell the stuff.
I wish Frank the best of luck. Running a business is hard. I respect anyone trying to make it.
Take care, bill
