I used the turkey baster method and got around 12 ounces of fluid out and it had an obvious green hue to it and was slightly brown. The fluid is undoubtedly the original and 5 years old with 73,XXX miles on it.
I added a $1.99 12 ounce bottle of the knock-off brand DOT 3 from Auto-Zone. The fluid obviously went in clear and instantly turned dark when mixing with the other fluid. I figure for $1.99 a bottle I will do it 2-3 more times over the next couple weeks.
