Originally Posted By: lars11
I think you are over-anxious about ethanol, and e10 in particular.
- Any engine for gas will need a richer carb when run on E-fuels. However, with e10, the differece would be one or two percent. Your small engine wont notice, they are too wide in spec. You could run a B&S on e85 if you opened up the nozzle for +30% flow and you wouldnt know it was e85, apart from difficult starts in cold temps.
- Ethanol is actually a better fuel. It is clean and it has a much tighter spec than gas. It would be easier to optimize an engine for e100 than for gas100.
- Corn ethanol bumps up food prices. But second phase production now being installed in bigger pilot plants use any carbon based stuff to make ethanol, like garbage, forestry and farm residue. Don't focus so much on the corn, that won't work in the long run anyways.
- E50-E100 won't ruin an engine adjusted for it, it will probably prolong its life because its cleaner.
- Two strokes may experience problem with high ethanol mixtures because the oil (made for gas) mixes badly with ethanol. Adapted oils should mix better.
- Boats have had problems with old fuel tanks made of inferior glass fiber resins. Thats a real problem, but only for some models. Theres no reason you cant make a fuel tank for booze.
- Rubber may deteriorate faster with ethanol in the fuel. Don't use ethanol when you suspect theres rubber in the fuel system.
All in all, its like any fuel: If your engine is not adapted, the fuel won't work well. If you tried making a Diesel85 mix, I can promise that it would work even worse than E85. That doesnt make diesel a bad fuel.
And stop worrying about E10, that is simply just gasoline. If you have engine "problems" with e10, you have problems anyways.
Gas will end some day. And if using second phase ethanol will prolong that time, I like it. Using corn for large scale fuel is questionable but that will go away in a few years.
Well said lars11. Thanks for your input on this.
