Since I drive a VW Passat 1.8T, I use Mobil 1 0W-40, the only Mobil 1 with the VW 502.00 stamp of approval. In another forum, someone who is no longer on engine warranty suggested Mobil 1 5W-40, instead, because it is a bit more readily available to him, at a somewhat lower price.
I suspect, but do not know, that the only difference between Mobil 1 0W-40 and Mobil 1 5W-40 is pour point depressants, which aren't of much use to me in San Diego CA. Are there other differences between these two formulations? Is there any reason the 5W-40 should be either better or worse for a turbo in a very temperate climate, or does it really not matter?
