This is my third UOA on this vehicle. The first UOA was with unknown dino oil (when I purchased it), and the remaining two are with the Mobil-1. Mann 940/25 oil filter.
I suspect that I have a PCV system problem, so I will be replacing every valve depicted in the PCV diagram. (Oil is being forced through the oil filler cap). Not enough oil comes out to necessitate adding make up oil, but it's enough that is slicks the sides of the engine.
