Recently got a 71 Triumph TR6 with 76K for a weekend "beater", planning to use it once or twice a week 9 months a year, maybe 3K annually in Southeast Pennsylvania. TR has a straight 6, not a high compression or high rpm engine redline at 5500, more typically run between 3500 and 4000 rpm
Moss Motors advertises (at almost 6 bucks qt. in case lot)
that "Collector's Choice engine oil is a must for your classic engine. Contains 'pre-ban' ZDDP levels . . . ."
The FAQ for "Collector's Choice" states that diesel oils are not good substitutes for ZDDP car oil because their high detergent levels maintain more contaminents in suspension and have a lower surface tension, with accompanying shear reduction, all of which increase wear compared to ZDDP car oils.
On this site, I've seen the posts suggesting both 15W-40 diesel oil and 20W-50 oils for similar high milage old cars. And I read through the article on molybednum added oils as superior to ones with zinc.
So I have a couple questions:
1) is there any information about the "Collector's Choice", a 20W-50 manufactured by Hicks Oil?
2) Is the diesel detergent level analysis valid or relevant?
3) should I stop fretting about ZDDP and just find a good moly added oil instead, and if so, which are available?
4) Is it true, as I heard, that, besides the milage reduction it causes, the strain a 20W-50's greater viscosity puts on the oil pump offsets the value afforded by the greater protection which is lost anyway as the multi weight degrades?
thanks for any guidance!
