My friends recently started overheating sometimes on the highway. I opened the hood and checked under the cap and saw crud caked up on the cap and brown coolant. The coolant pipes, where the hoses attach to the metal pipes that go into the block, look like they had been eaten by battery acid, they had those white crusty deposits. The coolant reservoir was full, but all that dirty coolant has never been changed in 150k miles. Car only overheats on the highway. I didnt see any leaks, and both fans go on. The upper-rad hose also gets soft and hard in response to changes in temp, so I dont thik the thermostat is stuck. What do you guys think, is it the waterpump, or clogged radiator or something else? On another note, I happened to check the tranny fluid and it was black. I asked if it had ever been changed, he said no. 150k miles on factory fluid and no tranny problems...lucky guy.
