Excellent responses.
In terms of applications, Rust and Oxidation Inhibited (R&O) oils are considered in the group of Industrial Hydraulic oils.
Some R&O oils are rust and oxidation inhibited only, but most today are AW R&O oils (AW Hydraulic oils), that contain ZDDP, moly, antimony, or boron compounds to aid in anti-wear funtionality. R&O oils contain no detergents. Some R&O oils have been used to simply coat steel or iron until further treatment or manufacture. Most R&O oils have been replaced with AW hydraulic oils which may contain Viscosity Index Improvers that have Pour Point Derpessants. AW Hydraulic oils usually have the better base stocks than do R&O oils. AW Hydraulic oils are usually made from Group II+ to Group V oils, while R&O oils usually cling to Group I or II oils.
Some R&O oils or AW hydraulic oils may be found in compressors as well, although specialty compressor oils have mostly replaced these oils.
It was found that with simple R&O oils, that when the oxidation inhibitor is consumed, wear increased. With higher pressure pumps and more tightly clearanced valving, more anti-wear qualities had to be added and of course, these AW adds also provide better oxidation inhibition.
The multipurpose THF fluids were designed to meet or exceed the tractor fluid specifications for J.I. Case, John Deere, and International Harvester farm tractors.
Tractor Hydraulic Fluid (THF) fluids serve as transmission fluid, hydraulic fluid, and gear oil for these applications. The viscosity is in the range of SAE 10W20 or 20W30. They must have very high VI, low pour point, Extreme-Pressure (EP) characteristics, outstanding Rust Inhibition, and oxidation resistance. They also have some detergents and dispersants.
For non-severe coating applications, the THF's could do the job, but NOT vice versa. Besides, the THF's are more expensive, so it is not economical to use THF's to replace R&O oils.
[ September 09, 2003, 10:39 PM: Message edited by: MolaKule ]
