I haven't owned a bike in 10 years and what a shock the prices are! I wanted an entry level mountain bike with a decent frame that I can upgrade later on if I choose to. I wanted it mostly for exercise but will probably take it on a few trails in the mountains once in a while.
I ended up getting the Specialized Hardrock XC with disk brakes. This is all the bike I could every want for recreational use. Only one question.. It comes with 6" 160mm mechanical brakes front and rear. It has enough power to lock up/flip me over the front wheel. What I have noticed is when I purposely do a lot of heavy braking the disk gets very hot which I assume is normal. No sign of fade at all. Just wondering if these will let me down on a long downhill stretch. I weigh 210lbs.
I'll probably see if they fail first before upgrading the front. Does anyone know what's involved in swapping to a bigger 180mm or even a 200mm rotor on a bike already equipped with disks? It would be nice to just replace the rotor and space the stock caliper out the appropriate amount but something tells me it's not that easy.
