Originally Posted By: c3po
Let me try to give some insight to this, you took the car to a Nissan Dealership if I am correct, this is a Ford product, you could have some Nissan fluid in there, did they change your transmission filter, this sounds like your transmission filter is clogged, I bet you have the felt type transmission filter. I once had a felt type trans filter on my El Camino and it did kind of the same thing, the rpm's went up and it was a delayed shift, I went back to the screen type trans filter. It also sounds like they did not drop the pan, when I did Auto-Rx in my trans I dropped the pan and the bottom of the pan had a layer of metallic sludge. If it were me I would go and get a case or more of Mercon V, drop the pan and if you do not already have 1 get a drain plug put in, I would do this T-Tech thing yourself. A T-Tech is not worth anything without dropping the pan and changing the trans filter. I did the Tranny Calculator thing. I did go through 40 quarts of fluid but I still came out ahead. 40X $2.50 equals $100.00, my opinion is a T-Tech pushes fluid through the pan and out the cooler lines, you are mixing old fluid with new fluid and not really getting all of the old fluid out. If you still want to do a T-Tech you may need to go too a Ford Dealer.
Some very good advise here, if you can't find a T-Tech machine, drop the pan, clean it and install a new filter. Then run the car thru all the gears, either suck out fluid from the filler tube, disconnect a tranny cooler line, or install a drain plug, and flush the fluid manually until its as clean as new. (There is a good procedure for doing it somewhere on this board and can be found with a search). As mentioned this can take several quarts of fluid. Any kind of flush machine is still using the old filter and could possibly be just pushing more junk through the system as it flushes it. I believe the T-Tech machines are good for a transmission that has been properly maintained and is in good working order that has a good filter to begin with. In your case the filter could be clogged. If you do decide to go the T-Tech method get the pan cleaned and a new filter installed!
JMo,
Frank D
JMo,
Frank D
