Had a friend over to experience a few hours of the joys of farming yesterday (e.g. I had some free slave labor!). My big tractor has some hydraulic leaks so before going to work, job one was to top it off. I told him to get the "black 2-gallon jug" and pour the entire amount into the trans. Well, he did. But I forgot I had TWO black 2-gallon jugs, one full of THF and the other with "dribbles," my drainings of new oil from jugs that I use in oil cans and such. As it happened, the nearly full two gallon jug contained about 3 quarts of slightly used Amsoil 75W90 Series 2000 syn gear oil (used for a few hundred miles in a gear oil test I did a coupla years ago) and most of the rest was overage, but unused, Type F ATF (4-5 quarts) and probably a little Rotella-T motor oil from the last coupla tractor oil changes. He didn't quite get ALL the stuff in before I got wise, maybe 6 quarts of the mixture. I topped of the rest of the way with THF.
Considering the system hold 24 gallons, I doubt I have much to worry about but I'd feel better if someone patted me on the head and confirmed that. I'm only about halfway through the OCI on the oil, so I'm not anxious to do a change at the moment.
