Hi, first post here, although I've read the forum occasionally over the years. I'm going to be putting a SR20DET into my 240SX soon and I'm trying to pick oils for it. I do track events pretty frequently with the car, and it's not a daily driver, so I'd like to be sure that oil will be ideal for 20+ minutes on the track at a time. All other considerations are secondary, especially OCI since I put on so few miles that I'll be using a low OCI. I'll be running an external oil cooler and expect oil temps around 200*F on track based on others' experiences with similar setups. Factory recommended fill is 10W30, or 5W30 for extreme cold temps. I was thinking of trying M1 10W30, but then I read up on here and noted PP and GC. Suggestions?
I live in Chicago, so I'm also curious if I'd be better off switching to a thinner oil like M1 5W30 in winter for the limited street driving I do. I'm gonna block off the oil cooler because others with similar setups noted overcooling in cold weather, due to the thermostat still routing some oil to the cooler below the opening temp.
Thanks all!
Thanks all!
