Quote:
Not at all. You have a current 120% capacity with conventional power production (in whatever form it is). You then install wind generators. Those plants then reduce production as power is available.
That ASSUMES that you have 120% capacity. We are going to need more than we already do and by quite a bit. Coal, nuclear = reliable. Wind...not.
If 20% of your RATED power potential comes from wind, but it only delivers half of that 2/3 of the time, you would need 90% conventional capacity to have a reliable system.
If you want to say that wind supplements your 100% conventional coverage fine...as long as the economics work out. Since they are not in wide spread use and the technology has been around for a long time, it makes me question this.
IF the windmills are economically viable (i.e. no need for gov. help) in a particular area, then I have no problem with them. Individuals that have them like Shannow's farmer and those in Texas that make a profit off of them (with or without subsidizes???) are a good thing.
