This is what it calls for according to Wix. VW/AUDI 30+/- bypass valve setting used on many late models.
Part Number: 51191
UPC Number: 765809511910
Principal Application: Audi (95-06), Volkswagen (77-00, 05), Case, Fendt Tractors, Komatsu, M.A.N., Renault Trks.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 30
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 345
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
The PH3569 xref
Part Number: 51452
UPC Number: 765809514522
Principal Application: Audi (78-83), Dodge V10 8.0L (94-99)
All Applications
Service: Lube/Transmission
Type: Full Flow
Media: Paper
Height: 5.178
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 415
Nominal Micron Rating: 19
Gasket Diameters
PH8A
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 290
Gasket Diameters
PH16
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Burst Pressure-PSI: 275
Gasket Diameters
I'd go with the regular old FL1A/PH8A/51515 filter ..but that's just me.
