From the BG website:
"BG Engine Purge is not an ordinary engine flush. It is an effective blend of solvents and dispersants which will quickly and safely remove accumulated sludge and other deposits from the engine. It can actually restore compression by removing soot and deposits from around the rings; hence, the compression rings seal in compression gases. BG Engine Purge does not contain harmful chlorinated solvents. It may be used in gasoline, diesel and rotary engines."
I wonder how it compares to Auto-RX? I know BG is a reputable company that makes excellent additives.
