Kinda strange topic, but wanted to know. Is the size of the nut(the part you attach the wrench to) going to be the same size, NPT or M3,5 or whatever. I have a coolant temp sensor I want to check the thread size on, but I can't get it out without taking out all of the coolant. Will the size of the wrench that fits on it indicate the size of the threads below it? I don't really have a safe place to dispose of the coolant. I am trying to fit a coolant temp gauge, and it's either T off the stock one, or cut up a hose and put a fitting in, which will also require draining coolant.
