Originally Posted By: Vesta
I live in Australia and the temp here is anywhere from 5c to 40c during the year. I have a 2007 Toyota Corolla and the specs range from 20w -50 down to 0w -20. I intend on using Amsoil SSO 0w -30, do you think this is a wise choice based on the temp range here?
I'd say that it's a fine choice for a mixed bag of usage. If you do mostly shorter trips, you can go lighter. If you're doing mostly sustained high(er) speed bouts (of longer duration) ..there's not much reason for NOT going to a 40 grade (if convenient) ...but the 0w-30 will work fine.
(how can I say this in 25 words or less?): I see no disadvantage to 0w-30 SSO. There may be further advantages to a lighter oil if you're someone whose primary usage is of 20 minutes or less per event. The shorter the events ..the more the difference. This is where viscosity differences may show themselves in fuel economy. From a (the nebulous definition of "protection") viscosity standpoint, oils appear more alike when hot.
