specs:
no priming bulb
139 CC
choke - yes, yes it does work
not impressed with it.
Update:
looks like overfilled the oil, it smoked like a mof% I pumped some out and cleaned the spark plug and started up after the first turn with gas injected into the spark plug hole.
I want to add an inline fuel filter, but this fuel line has a clear 1/4 tube inside of the fuel line, what the heck is that?
I changing oil this weekend to tropic 10w30
I added tad bit 2 cycle (castrol syn) to gas.
I tried starting it next day, it started on the second pull, yes it was in the blistering michigan heat at 60F ;-)
thanks everyone for their input.
