I changed the oil on my buddies car and noticed a few drops of coolant, he said that he has to add about a gallon of coolant every month, its worse when the weather is warm, he does not see any steam or drops of coolant on the ground, probably because when you change the oil you have to drop a big plastic tray down, when I dropped it down I could see a few drops above, could he have a lower radiator hose that is slightly leaking, heater core blows hot air, car does not overheat, car seems to run fine, I just do not have any experience with Subaru's to give him any suggestions, any thoughts would be appreciated because he is a great friend.
